I have a 1997 Four Winns with a 5.7L Volvo Penta Motor in it. I have 2 Fuel Pumps on the motor. One on the front left side of the motor that has the Water Seperator Filter attached to the housing.
The Second Filter is on the top back of the motor same left side of the motor. The Pumps look identical minus the brackets.
I have been told the one in fron is a Low Pressure Pump and the one in back is a High Pressure Pump. Looking up the pumps on Iboats i only see one pump listed as a replacement for both.
How could one pump be a loq pressure and a high pressure pump at the same time? Are they actually the same part number for both?
