polarbear06
- Apr 8, 2012
- 4
I can't get my engine started and it seems to be a spark issue. I already replaced the plugs and plug wires. i removed the wire from the coil to the distributer and installed a spark plug on it. Turning the engine over, there was a spark across the plug but it was very weak. I figured, new coil. Well, new coil, same results. Checking the voltage from the battery to the positive terminal on the coil shows 12.3 volts with the ignition off. Turning the ignition on (not cranking it) caused the voltage to drop to 1.3 volts. Checking the voltage across the coil showed 6.3 volts with the ignition on, dropping to 3 volts when you crank it. Anyone got any ideas where I should go next?
