Re: Alternator problems? 1996 4.3 Volvo Penta Engine ID#4110124372
Was the alternator rebuilt or replaced?? If replaced, was it the correct alternator?? Make sure you have the right one.
I took the part number from the old one and researched it before I bought one. I gave the mechanic a wiring diagram that I pulled from the net specific to the motor/drive. After posting that yesterday I puled it and checked his wiring and it was not wired per the diagram. I corrected it and still have the same problem.
I have had this boat for years and and remember what it did when this fuse blew in the past, this was not a problem before the alternator change but there have been a lot of different hands under the hood so anything is possible.
If I had a short I thought that it wouild blow the fuse at start up, not after reaching a certain rpm?
There are two of the 50 amp resettable fuse links daisy chained together, this is the second one in the loop, if I switch places with them and the same one still blows would it prove the fuse to be the problem? They are about $100 so I don't want to just run buy one.
Thanks for the help!
