ahoi ! today i found a pushed freeze plug on the exhaust manifold on our 3.0GS engine. i winterized the boat , but relativly late and maybe one or two nights below freezing level passed by- thats at least my guess since the plug loooked good and whatelse than freezing should forced it to fell out.
i looked very carefully with a flashlight the whole engine block as well the manifold and found no cracks on it, also no water in the oil.
since thats alone not a guarantee for internal cracks to check for sure you have to run the engine on muffs and see. so my plan is to just hammer in the freeze plug again , crank dry the engine without spark plugs to check if there is water in the cylinders and run it . what do you think ?
can i just hammer in a pushed freeze plug , will it hold when pushed out once? ? when the engine runs good and no water in the oil, can i assume i had luck ?
cheers !
cheers !
