RickKennedy
- Oct 3, 2010
- 5
It is a temp sensor. I have the same one in my 96 Chap 2330. I pull that and another plug from the bottom of my manifolds when I winterize. I believe the sensor is on the stern side. That may have been one that was replaced or look for the hole and dangling wire.
Good Luck
My 96 5.7 Gi has two block drains,one on each side right under the manifolds. The one on the stern side has a plug I pull off to unscrew the plug. I assume its sensing temp and not pressure or it would have a hole in the end. My boat is in NH so I can't take a pic of the plug. The first post pic looks like the plug I pull. Maybe mine only has one tab, I don't recall. Either way I think RickKennedy could look in this area to make sure theres something in the block drain holes.
Just a thought
