I have a 2003 Crownline with twin 3.0 GLM volvo engines. One of engines does not pump water with rabbit ears and therefore overheats but the same engine does not overheat when the boat is in the water. I disconnected the raw water hose and put the hose in a bucket of water and it will then pump ok. Guess the problem must be in the outdrive but have no idea what to do. Any ideas??
