alandchris
- Dec 25, 2007
- 106
Volvo Penta 'requires' using a mixture of gas, sta-bil and 50:1 two stroke oil to "fog" a fuel injected motor for winterizing.
The question is, is it best to leave the existing fuel filter on for this step in winterizing - and then in the spring, just before 1st launch, install a new filter WITH fresh gas at that time ? This may be a problem tho, if there is water in the existing filter - ie a freeze will crack the fuel filter?
My concern, I guess, is that I don't know what problems would happen if I used a new filter and ran that mixture thru it - and the 50:1 oil would be embedded in the filter, would that cause a problem come spring time
Or should I run the mixture thru, and then change the filter to a new one, then run the boat again for a while without the mixture, ie the gas in boat's tank with sta-bil. Would running the motor, after the mixture "fogging", with the regular gas, "clean out" what was done by running with that mixture previously, thus reversing the point of the "fogging".
