nramirez1978
- Aug 9, 2011
- 7
Hi,
I was wondering if somebody knows the steps to winterize a bayliner Capri.
I have a volvo penta AQ 225e V8 with a 275 OD. 5.0Lt.
by reading on these forums i been able to gather to the the following.
1-put in Fuel stabilizer (ran engine for a few min)
2-once boat is warm (change oil and oil filter) NEED HELP finding the Oil Drain plug
3-fill up fuel tank and add more stabilizer.
4-drain all water (which i can do by unpluggin all hoses and 1 plug from each size of the engine)
5-Add Antifreeze to flush all the water out (NEED HELP FINDING WHERE AND HOW DO I ADD ANTIFREEZE) i tried looking for some plug so i can add antifreeze, but was unable to find it.
6- Do I put the hoses back on?
ALSO--i'm thinking about changing the spark plugs and changing the oil from Out Drive before i take it out next year..
is there anything else that i should do to my boat to get it ready for winter? TEMPERATURES GO AS LOW AS 25 DEGREES
does anybody know where i can get a "service manual" from?
Thank you..
Thank you..
