My Trim / Tilt pump is intermittent. The plastic connector on the harness going to the pump motor seemed loose so I hard wired it which didn't solve the problem. The relays klick when I toggle the trim button on the throttle but the pump doesn't work. I haven't taken the relays out of the sockets but could corrosion be the cause ? Bad ground ?
