2003stardeck
- Sep 30, 2011
- 2
i have a 2003 volvo penta 5.0L GL that was overheating. i replaced the thermostat and experienced no overheating however when i slow the boat down and idle around, i notice that the temp gauge rises 20-40 degrees. As soon as i get back on the throttle the temp gauge drops back to the normal operating temp. Can anyone tell me if this is normal and what the temp range should be on this engine. it seems like to me it is not moving enough water at low speed. Thanks.
one other note. before i bought the boat it was run onto a sandbar and trashed the impeller. They did install a new impeller but when i decided to replace the thermostat i found 9 pieces of the old impeller in the thermostat housing. where else should i be looking for pieces of the old impeller?
