Aloha,
I'm the proud owner of my first boat, a 1997 Regal 2100 LSR, Volvo 5.7L GL PLKR with the SX-C Out-drive (I'm relatively sure this is correct, out drive has been painted, no tag left).
It's a great boat, ran a compression check before purchase, all numbers were in the 160+ range, and the 2 Barrel Carb has a fresh rebuild. However, I'm not satisfied with carburated performance in general. The boat is regularly somewhat hard to start (2-3 attempts before she stays on), and also has a tendency to cut off while idling, or when slowing to idle from a hard run. Also standard power drop when cornering hard.
I just replaced and properly gapped the plugs (NGK - BR6FS), and I've been over most of the other standard maintenance items.
I'm sure that with some time/energy/money, I could get the current carb running much better, however, I'm an EFI tuner type, and I'm much more interested in the functionality and ease of use of converting over.
After doing some homework, I tracked down Affordable Fuel Injection, and from the posts I've read they do a very good job, and have a good reputation for customer service.
My current decisions are whether to do merely the TBI setup ($1,700), a MPI install ($2,400), or a TPI system ($2,625). I've seen a few posts where people installed the TBI, and later said they wished they had gone with MPI/TPI.
My engine also unfortunately has 12 intake manifold bolts, so I'm under the impression that is indicative of a NON-Vortec head setup. I understand that converting this over could easily net more than a few extra HP, the question being both how much HP, and how much additional cost would this add? Are there any great manufacturers out there who can sell me an easy and complete package, without having to source a ton of parts individually?
I'm personally a gear head, and I'm more than familiar with the loss of money spent on fun projects, so while there is no firm budget for this part of my boat build, I'd like to see everything done correctly the first time, but without going exceedingly overboard for only a small net increase.
Any guidance/input? Thanks! -Ian
