I need to know the torque lbs and pattern for my 1998 engine heads. Thanks, Don
I inettrvlr Recruit Joined Sep 26, 2011 Messages 5 Sep 26, 2011 #1 I need to know the torque lbs and pattern for my 1998 engine heads. Thanks, Don
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Sep 26, 2011 #2 Re: Volvo 1998 4.3 GL headbolt torque lbs and sequence Attachments 4.jpg 70.9 KB · Views: 2
I inettrvlr Recruit Joined Sep 26, 2011 Messages 5 Sep 27, 2011 #3 Re: Volvo 1998 4.3 GL headbolt torque lbs and sequence Thanks Don! Can you also tell me the torque for the exhaust manifold & intake? Thanks again. I have been trying to find a repair manual with no luck. Don M.
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Sep 27, 2011 #4 Re: Volvo 1998 4.3 GL headbolt torque lbs and sequence IF your engine is actually a 98, here is the engine manual for it. Boat year and engine year is not always the same. However, engine torque didn't change in a couple of years older or newer. http://www.4shared.com/document/_WwAaZ4U/7797451_BY_Engine_Manual.html?
I inettrvlr Recruit Joined Sep 26, 2011 Messages 5 Sep 27, 2011 #5 Re: Volvo 1998 4.3 GL headbolt torque lbs and sequence Thanks for the link. 392 page pdf file should have everything I need. Don M
