I purchased the petronix kit for my aq131a and am stumped with how to wire this thing up correctly. I also got a new flamethrower coil for the Petronix kit.
Currently my old coil was wired like this
To the (-ve) terminal i have only 1 gray wire connected that went to the wiring harness. Im guessing this is for the tachometer
To the (+ve) terminal i have a white wire that goes to fuel pump
Also, to the (+ve) terminal was connected a Purple wire that went to the wiring harness. Not sure what this connects to. Im guessing the ignition switch
To the condensor on my distributor i had a purple wire hooked up as a multi point connection that also connected the contact point.
Now, How would i hook up thepetronix kit? Do the old wires on the coil go to the same +ve and -ve terminals on the new coil in addition to the ignitor module red to +ve and black to -ve on new coil? Also, most importantly where does the purple wire that went to the condensor go to?
Any help would be appreciated.
Almost forgot, the petronix instructions call for the possibility of having a ballast resistor. What does this look like and how do i know if i have it?
