Hi. I have a 1998 Volvo I/O 4.3Gi and have found both block drains, removed water pump hoses and manifold hoses to get the water out for winterization. My question is what else is there? The manual calls for the removal of a drain plug for the intake manifold??? I see what looks like a square headed plug on the front of the intake manifold, right above the water pump but it looks like it has never been removed nor do I see way to get at it since the alternator bracket and a wire harness block access of getting a socket on it. There is also mention of a removing a small hose at the top of the thermostat housing called 'bypass hose'? Did that but no water came out. It calls to remove it somewhere in the back of the engine and blow air through it. I just wanted to ask someone who had winterized this engine before, what exactly is needed as I would prefer not to remove half the engine parts if not needed.
Thanks,
Thanks,
