doberacker
- Jul 26, 2011
- 39
Ok, I took off my trim/tilt unit 1.5 years ago, worked FINE. I just couldn't use as it was hitting the hull on boat. I just sold the unit to my buddy, and he can't get it to work??? He said he tried to just "put hot/ground" to the motor on the unit and couldn't get it to work? I remember that I had the Black wire and RED wire out of the switch box hooked up, and the wires to the MOTOR had plugs that ran to the switch box. Then the wire that went to the console had the wires that ran the switch. I "KNOW" it worked when I took it off. Maybe it could be that he doesn't have the wires connected right? He only tried to run the motor by itself? I am going to pick the unit up in the AM, but would appreciate ANY ideas you all would have? I just want to test and make sure it's working properly. There must be a way to test to see whats up without having to hookup the unit to a throttle set with the "trim button"???? Daryl
