craze1cars
- Dec 26, 2004
- 1,822
1999 5.0 GL PWTR.
I have a slow raw water cooling drip into the bilge, from the rear of the motor. Using an inspection mirror I can see it is dripping out of what appears to be a small slot (probably a low-spot drain?) at the bottom of the starter, near the starter teeth/flywheel engagement area. Approx one drip every 5 seconds, only when engine is running. It does the same when out of the water running on muffs, so I know it is not lake water coming thru thru transom housing/bellows or similar.
I will pull off the starter after the season is over and try to look for rust streaks/signs of the source of leak,..but the bad news is I probably can't see it running and dripping from the source if I remove the starter, because I won't be able to start the motor without a starter! (Though I suppose I could MAYBE start the motor, let it idle, and carefully pull the starter off while it's still idling...I'm not crazy about that idea)
So in the meantime...what's up under there? Where do you suspect this drip might be coming from? Is there a casting/freeze plug hidden up under the starter? That's my best guess...your input is appreciated if there are other things in that location that might be causing this drip.
Thank you!
Thank you!
