Recenty purchased a 87' Invader with a Volvo Penta AQ131A/275. Boat has last been run in 2005. After a feww hours with the boat, have figured out that we aren't getting fuel at this point. We have figured out the fire and can get the boat going by priming the carb. Pulled the fuel line from the fuel pump and can suck gas out of the tank, so definitely the pump as the carb is not getting fuel.
Can I use a fuel pump from a regular Volvo engine or does it have to be marine specific? Boat will only be in freshwater. What car model works for this engine? Additionally, the manual says to pump the old engine oil out even though there is a drain. Is it not recommended to simply drain it with the drain plug?
