Hello
I have a
2004 Four Winns
3.0 litre Volvo GLP-C (3869250 4012108750)
Transom TSK SX-M (3868844 4151044430)
When starting the engine, I will get a click sound, then when I try it a few more times, I will hear a ping sound like the starter gear hitting the flywheel. Then the next try it will start? Sounds like an alignment issue?
When I bought the boat second hand, the owner had just had the starter replaced by a marina service shop. I could see that it was a different starter as the colour was different, so I know it had been changed. I believe that this could be an issue due to the bracket is not installed on the starter to the engine? Marina did not replace it I guess or lost it? What I am looking for is the correct part number for a new starter and bracket/ accessory kit (bolts bracket shims) and also a location around Ottawa, Ontario, Canada to purchase one.
I had another person mention to me that it may be a relay issue?
Also another question, is this engine actually a GM? And could I get a GM marine starter?
Note please verify that I have found the correct part numbers for the 2004 Volvo Penta 3.0 GLP-C s/n 4012108750.
Relay #3861375
Starter Motor #
Starter 30
3.0GLM-C, 3.0GLP-C
7744460 - 30 - 6859 20106 Upd: 04 JAN 2006
3.0GLM-C, 3.0GLP-C
REF PART NO. QTY DESCRIPTION
1 3587625 1 Starter motor
2 3810300 1 Solenoid kit
3 3854496 2 Washer
4 3854752 2 Screw
5 3860840 1 Brace
6 949874 3 Lock nut
7 3857146 1 Screw
8 855314 1 Nut
9 947107 1 Flange screw
10 855798 1 Protecting sleeve
When I search on the internet for the 3587625, I keep finding this part number with a -10 after it? But I am not sure if it is the correct one?
Any help is appreciated
Thanks
AGY
I have a
2004 Four Winns
Relay #3861375
Starter Motor #
Starter 30
3.0GLM-C, 3.0GLP-C
3.0GLM-C, 3.0GLP-C
3 3854496 2 Washer
4 3854752 2 Screw
5 3860840 1 Brace
6 949874 3 Lock nut
7 3857146 1 Screw
8 855314 1 Nut
Thanks
AGY
