SEASPORT22
- Aug 9, 2011
- 3
I have a 99 volvo-penta 5.0GI with a DPS outdrive. I'm new to an engine with a heat exchanger cooling system as the last boat I had just had a raw water cooling system. I'm starting to think about winterizing it soon and was wondering about the areas that are cooled with the heat exchanger and the areas cooled by the raw water system. I was thinking that the heat exchanger system is closed and cooled all the internal engine areas like the heads and block as well as the power steering cooler, can't find an oil cooler on mine, (could be there, but I haven't found it yet). That being said, in terms of draining down the engine for winter, can I just drain the raw water system which would include the raw water pump, both hoses that come and go to it, the manifolds and the heat exchanger? also looks like a hose going to the outdrive that would raw water in it to drain. A Clymer manual came with the boat when we bought it and it, in my opinion, is very poor at describing the areas with anitfreeze in them and the areas with raw water in them and what areas need to be drained before freeze up. Also, curious to tricks to run the stabilizing gas through the engine when I shut it down for the year. Do you recommend a shot of fogging oil in the cylinders too? hearing mixed ideas on this.
Thanks.
Thanks.
