- Jul 23, 2011
- 47,561
Have an 88 AQ271C with a DP290 drive. now the quest for more power. going to take this in phases: update stock, simple bolt-on mods, then ??? plan is to get the boat to 50+
starting to stock-pile a few parts.
first things - simple carb go-thru. new power valve, gaskets, and maybe play with the vacuum diaphram springs and the jets.
after that - 1.6:1 rockers on stock heads. Anyone know how close the current volvo cam brings the valves to the pistons? would hate to violate the fundamental first law of physics. If not, dial indicator time.
this winter the plans are to source a decent set of heads, a different cam, and a different intake. May look into a set of headers from Custom Marine. Just the weight savings alone there may make the boat faster by 2MPH
Any other suggestions?
last resort is to build a 383.
