I have a 1988 Volvo Penta AQ 260. Put in new trim/tilt motor, two new solenoids and replaced any wiring that looked bad. Motor will run if I go directly to battery with green and blue wire, one positive one ground and run in opposite direction when switch. But when I go to the solenoid it will not run. Could It not be wired correctly or is there a relay hidden somewhere. Checked for voltage and Im getting 12 volts to both solenoids when I hit switch either up or down. Seems to me I should only get it on one or the other (up or down). Any help would be great, drivin me crazy and just bought new prop cause we killed old one due to no trim . Thanks
