Alex_AGB
- Mar 9, 2010
- 42
Hello,
I picked up another boat recently and finally got a chance to get it in the water today. The boat hadn?t been in the water since 07 and the driveshaft bellow looked a little dry. I figured I take her for a run first to pinpoint any other possible problems before I replaced the bellow and I may have found a few...
When turning and trimming the outdrive up there is a vibration. The lower unit filled with water after just a 30 minute run. And the trim Gauge isn?t working properly.
I wont get a chance to tear it down until later next week so I figured I put up a post and try and see what parts I'm going to need for sure. Also this will be my first Volvo tear down so its going to be a learning process for me!
I plan on replacing the gimble bearing for sure along with the bellow and possibly a u joint if needed. Should I replace the trim gauge sender as well? Any other parts I may need or should replace please let me know.
Thanks!
heres a pic of the outdrive...
Thanks!
