Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Help me ID my Volvo 4 cylinder motor
This topic is closed.
  • Help me ID my Volvo 4 cylinder motor
    It's hard to order parts when you don't know EXACTLY what engine you have! The air cleaner cover is no help (scraped/peeled) and I couldn't find any metal model tagging by the starter/bell-housing.
    Here's what I know:
    - Boat is a 1983 Bayliner Trophy
    - Engine is not original
    - Motor is cast "B230" next to oil filter
    - Intake has "46408" marking
    - Timing cover says "B230F" and "NR: 6670"
    - Head is cast "1000" and "531"
    - Lower Unit is Volvo Penta 270
    Here's what I think:
    - Prior Owner told me it's an AQ125
    - Looks to be an junkyard auto engine
    - Closed cooling system was removed at some point (uses raw now)
    Here are some pictures. Let me know if I you'd like pictures of anything else, or if I can look anywhere on the engine for more markings.
    Port:
    Starboard:
    B230:
    Front:
    Top (disregard the coolant hookups, I was doing a pressure test):
    Any help is greatly appreciated!
    Re: Help me ID my Volvo 4 cylinder motor
    Here's what I know:
    Could have originally started as an AQ125A if it had a B21 block instead of a B230 block (exterior of both blocks relatively identical).
    In it's current form, you could more or less consider it an AQ125B (minus the closed cooling).
    http://www.volvopentastore.com/Marin...view_id.765104
    Non marine specific parts from a mid '80's 240 series Volvo car should fit. This obviously excludes the distributor, starter, alternator (the delcotron alternator installed in your pic's isn't factory and I question if yours is marine grade), and any thing else electrical. Should also check to see that the engine has a marine carb, and marine fuel pump installed.
    1976 Rogers Custom Boats 18' "Bonneville" W/ Chevy 454/ Berkeley 12JC
    Care Taker of 1976 Glastron V-184 Crestflight W/ Volvo 170B/280 I.O.
    & 1969 Starcraft W/ 1956 Evinrude 7.5hp Fleetwin.
    • #3
      I can't say I'd know how to tell those things. Any tips?
      Right now I'm looking at a possible blown head gasket or cracked head, and the exhaust manifold looks to need replacing. Any idea how much a head for one of these would run me?
      • #4
        Can't tell by your pic, but if your fuel pump has a line running from the pump body up to the flame arrestor, it's most likely marine. Take a pic of the carb and post it. May be able to confirm by looking at it. Most Volvo's were injected by the time this boat was put together, so chances are the carb on this is marine.
        All the delcotron alternators I have seen put into marine service usually have flame arrestor screens around the openings in the alternator case. Yours looks like it was bought at an auto parts store.
        You should stick with that that thread for asking that question. In all honesty, the questions you asked in this tread could have been answered in the other one (I was not aware the other existed). It's usually easier to keep all related questions in one thread.
        • #5
          Every Volvo 4 cylinder with a timing belt came with a closed cooling system. Mostly due to the fact they had to run at such a high temp (190į thermostat). If it's used in salt water, it probably won't last long, and with the amount and type of corrosion I see, it's salt water.
          Your's looks a lot like a car engine block installed with the 125 accessories installed. Volvo didn't use that belt cover on marine engines. The cooling system is home made, and I can see no way to cool the exhaust while the thermostat is closed.
          I would strongly suggest you go looking for a used Volvo 4 cylinder OHC engine complete and start over.
          Don S.
          Please, no PM's (Private Messages) regarding boat/engine problems.
          That is what the forums are for.
          Only forum/moderator issues will be answered in PM's.
          • #6
            Thanks Don. A bit more horsepower would be nice. Which motors would be compatible with that lower unit and bell housing? I'm assuming it has to have the same ratio (which I'm not exactly clear on).
            • #7
              Only a Volvo 4 cylinder is going to be both compatible with your flywheel cover and gear ratio in the L/U. I believe the AQ131/145/151 engines are similar to what you have in there now, and would make a little more power. The AQ171 is the DOHC I4 that Volvo used, but I believe parts for it are getting a bit rare. Don may know better...
              • #8
                The DOHC engines do have some cooling system parts that just doen't exist anymore unless you are lucky enough to find used. But they weren't used that often either. As mentioned, the AQ131/145/151 will bolt right in and all have more hp that your 125 mess.
                Don S.
                • #9
                  Can I move into a v6 with my LU setup? Like a Volvo Penta 4.3GS?
                  • #10
                    Nope, not easily easily or cheaply. You wouldn't have an exhaust Y to the transom shield, no Flywheel cover/bellhousing, flexplate, wrong gear ratio in the drive (NO, different props won't work very well) .
                    Other than that, not too many other problems.
                    Don S.
                    • #11
                      According to the B230 stamp on the block and then post #3 here:http://www.bdoutdoors.com/forums/boa...-outdrive.html you already have an AQ151, the AQ125 would be a B21. Which, if that's right, then you have the wrong carb (yours looks the same as the single barrel solex on my aq125).
                      1985 Bayliner Capri Bowrider 195, Volvo Penta AQ125A/270 http://s290.photobucket.com/albums/l...view=slideshow
                      1975 Valco 14' Aluminum, 1988 14HP Evinrude SPT http://www.flickr.com/photos/9572572...th/8739529784/
                      1995 Starcraft 24' Starfish pontoon, 125HP Mercury
                      • #12
                        As I understand it, an AQ125A is a B21 block, where as an AQ125B is a B230. The B230 block was used for several different AQ models, so the fact that he has a B230 doesn't necessarily mean it's an AQ151 or any other AQ model. In reality he more or less has an automotive/marine mutt installed. Theres no telling what the compression ratio, cam profile, valve size, etc is as compared to any AQ engine using the B230.
                        • #13
                          aq151 is a dual carb i believe. as stated the 125b used the b23 block.
                          '88 Baretta Success 200
                          Volvo Penta AQ260/275
                          '96 Weeres Suntanner 24
                          '01 90hp Johnson
                          • #14
                            I have a 125B in my boat an it looks very similar to yours, the problem is, you are missing the fresh water cooling unit that sits on the front. I have never seen a raw water cooled 4 cylinder, but I am no expert.
                            good luck on you endeavers.
                            • #15
                              Thanks. Because of the rigged raw cooling from the previous owner, the head corroded out and blew on that engine. I'm in the process of rebuilding a new swap. Thread here.
                              Back to Top
