Re: Volvo Penta AQ170a Water Pump
Thanks for your replies everybody. You see, my english isn't top notch but i'll have a new update for you. Yes it was the circulation pump that ill needed new because it is so rusty, but I have managed to remove most of the rust and got it going. So then the next thing I did yesterday was to open the sea water pump, with the rubber impeller inside, actually it didnt look to bad. But then ill discovered an unpleaseant thing. I have recently changed out the engine oil and the filter, and to my surprise it was much water that have mixed with the oil, so thats maybe why ill dont get enough cooling on my engine? Maybe its the state seal that needs to be changed out?
