2003monterey322
- Jul 8, 2011
- 11
I have Twin volvo penta 5.7 GI-D MPI's in a 2003 Monterey 322. I believe I got some bad fuel. Just got the boat and put a few hours on it my first weekend and filled up with gas in both tanks. I put about 200 Liters/65 gallons in each tank. Left from the fill up and one engine starting backfiring so headed back to the dock and the other engine started doing the same thing. Parked it at the marina where I filled up and it's still there to this day. The marina is an hour and a half drive away so it makes it difficult to troubleshoot when it's not right here. Volvo penta dealer said ithey are backed up for atleast two weeks before they could travel to see it. Took the fuel filter off, emptied it and it did have some water in it. I have since replaced the fuel filters on both engines, and added in fuel/water seperators to each engine. Now the engines will start up and idle ,but give them a rev in neutral they will rev for a second and then the engine will die. A mistake I made may give someone out there a clue as to my problem as well. The mistake was I took of the stock filter , emptied it, carried on installing the fuel/water seperator. By mistake, I started the engine without installing the original spin on fuel filter and let the engine idle for a few minutes and no fuel came out where the filter should be. I thought it should have been pouring out. Thoughts? Seems like they are starving for fuel. Very strange that both engines are doing the exact same thing.
