Hello
First post so thanks in advance.
Yesterday at the lake set off without any problem , out swimming for about 3 hours and pulled anchor to set off and the boat (2002 Glastron GX 185) stalls and quits running. Try to restart and engine starts and shuts off. Check lanyard remove and replaced same result.
One tow, $553.00 and 24 hours later in the driveway we check the fuel pump-no gas. Power and ground to fuel pump were working. Fuel pump removed and checked with extra battery in the garage and it pumps perfectly. Fuel filter not clogged. Put fuel pump back in boat and the boat runs fine in the driveway, Any suggestions? We are Considering replacing the fuel pump and relay as we don't have an explination for what happened yesterday or first thing this morning and not really comfortable going out again without an explination.
Thanks in advance
Roger
Thanks in advance
Roger
