Don S
- Aug 31, 2004
- 62,321
Did you check to see if water was coming out of the exhaust while it was running? If not, the first place to check would be the impeller. Pull it out and see if the vanes straighten out in about 15 minudtes or less, if not, but a new one in with some dishwashing liquid on it and try again.<br />There is also a hose connection that may be corroded away that is on the drive just below the ujoint bellows. If it corrodes off, the pump will suck air and not water.
