Re: 83 volvo penta aq125a timing help
There arent any marks on the belt. You line up all the pulleys with their corresponding marks, (cam gear has a dot that lines up on the head, crank at tdc and another one for the balance shaft. Put the belt on and add tension with the tensioner...****ROTATE THE ENGINE A FEW TIMES TO MAKE THE MARKS STILL LINE UP PROPERLY***....when everything is lined up, this is a good time to make sure the distributor is pointing at #1. Also, #1 is at the front of the boat and #4 is in the back.
