Hi guys, I need some help with a 2002 5.0L GXi in my Chaparral 220 SSi. Total hours on the boat 236.
I bought the boat 6 weeks ago, and have about 8 hours on it since. Some has been trouble free and we are enjoying it.
Some has been painful, and my newest problem has got me stimied. The first issue came up after 3 hours, I coudn't get full throttle. I was seeing 15 mph at 2800 rpm, no plane. I tried replacing the fuel filter, no effect. I was then told to use Star Tron treatment for the whole tank, assume that I have bad gas from winter storage. I tried this and after 90 minutes of putsing around at 2800 rpm, the boat magically started taking more fuel. By the end of the day I had 5000 rpm. At that moment, Star Tron was my savior. The next day the boat ran flawlessly, again 5000 rpm anytime I hit full throttle. One week later the boat started hard, but started. At that time I noticed the starter would not always engage. I was thinking starter trouble or weak battery, (however the starter's energy was excellent when it engaged, not like a sluggish battery). The boat again didn't take full throttle for about 15 minutes, but then then all was well. I was still thinking that I had a fuel issue and that I was slowly burning it out. The next day all was well again. It would appear that when the boat sits for more than 4 or 5 days, I have starting/fuel issues. Two weeks later I decided to install a new battery, (the two battery kit from blue sea). I started the boat first, it started hard, (3 or 4 attempts), and was rough at idle. At 1400 rpm in neutral it sounded great. I ran it for 15 minutes, shut it down, and installed my new fresh battery, noting else, (I never installed the new battery switch or charging relay). I tried to start the boat and after 30+ cranking attempts, no joy. I actually fried the starter, (which may have been weak anyways). So yesterday I installed a new starter, and did the following to make sure that the engine has fuel,
installed a new fuel filter
removed the suction line to the tank to check for blockage
removed the tank pick up and check valve, checked for blockage and check valve operation.
reinstalled everything, turned the key and confirmed that the pump(s) run for 2 seconds.
with the pumps running, I opened the shreader valve on the fuel rails to confirm fuel in the rails.
Cranked the engine 15+ times, never fired, never stumbled
My confidence is fairly high that I have fuel, although not 100%.
The boat has not started AFTER installing the new battery.
Any chance I have a memory reset issue?, the battery swap took 30+ minutes, (I ate lunch during the swap).
Is there any fuse that I could have blown during the battery swap that would prevent a start?
Assuming I have fuel, any spark at any time would give me some form of start, so I am now thinking that
something in the computer is either telling the plugs not to fire, or the injectors not to open.
Any help would be appreciated.
This is my fist boat, and was actually hoping for a full season of carefree boating. Hopefully I can get her back runing and start some carefree boating.
Thanks for your help in advance.
