simon081065
- Jun 27, 2011
- 5
A wonder if anyone has any ideas or has had a similar problem Ive looked everywhere on the net and cant find much
Its a petrol volvo penta 3 litre GL 2005
Already had a new thermostat, checked the impeller and blown air back through the system to check for blockage.
What happens is, every time I put her in the water she overheats straight away, then if you rev the engine she seems to manage to draw water into the system and is fine, she will idle on normal and also run at high revs without overheating however once you stop the engine it it does the same thing again on restart!
She is with the engineers at the moment but it seems to have them a bit flumuxed!
Any ideas, greatly appreciated?
