volvo penta 131 engine 290 outdrive
CHUCKR
I have figured out my impellar is not pumping water,which in turn cause my exhaust bellow to smoke.Im a auto mechanic by trade and was wondering if anyone has a pic. to post,with an<br />exploded view?The boat is a 1988 berretta with a 131 volvo and 290 series outdrive?I have also found a small water leak around silver collar for<br />"the plug" any products or suggestions on repair?
tommays
Re: volvo penta 131 engine 290 outdrive
if you got hot enough to melt the rubber you should be concerned what damage may have happened to the motor???<br /><br />the best thing you can do is buy service manuals for your motor drive combo there are to many littel things if your going to go DIY that are easy to screw up and caust big dollars <br /><br />tommays
