Anyone out there remove the tilt pins without removing the entire engine? I'm getting conflicting reports from mechs, both rams are confirmed leaking. Does anyone know if rebuild kits are still available? Those rams are hideously expensive.
If you have photos, that would help. I was thinking that if I could remove those pins, the mech could take over. I also think the universal is bad as the steering at extreme angles left/right produces vibrations. Otherwise everthing is pretty cool. Engine only has slightly over 300 hours, runs strong. Prop does have a few bends.
