I have driven my boat for the last 8 years without any issues whatsoever until yesterday. My boat started fine, ran fine until I parked it at a dock at the park in 96 degree heat. After sitting for 2 hrs I got back in and the boat started and I idled out and as I began to speed up and trim out, the boat just stopped. After many hours of trying to get it going I gave up bc I couldn't figure it out. Here are the things I tried:
*Used starter fluid in carb but it wouldn't fire
*After it wouldn't fire I figured it was spark plugs
*I took off the plug wires and really not sure I put them back on the right plugs bc I am a true engine novice
*Finally got it started and began to go out and test it but it ran extremely poor and I turned it off and then could not get it started again.
My question is, since it started, would it be spark plugs of maybe the fuel filter?
The boat only has 146 hrs and is clean and has always ran strong.
I would really appreciate any advice. Please and Thank you!!!
