Sparkinator
- Aug 15, 2009
- 423
I've had water leaking into the boat since I got it a couple of years ago. Not great amount, but more than it should leak. I couldn't find where it was coming from so I just lived with it.
The other day, it got to the point that I couldn't ignore it any longer. We parked the boat while we went for a swim, and when we got ready to leave, the engine compartment floor was soaked and the drive was stuck in the mud. I pumped it out (need to get that auto bilge pump, I know) and limped back to the dock.
After inspecting everywhere that water could be coming from, I removed the top cap from the transom shield where the steering linkage is and found that the gasket for the cap was worn. It's probably 16 years old, and eventually just lost its resiliency. When I put the cap back on, you could hear the metal hitting on metal, due to the compressed gasket. I've got a gasket ordered and should be back on the water shortly.
If anybody else has a leak (large or small) and hasn't checked this gasket, it would be worth a look. It sure was nice to find the leak fixed with a 3 dollar part vs. having to replace a transom!!!
The cover is 28 and gasket is 29 on this part diagram.
