Starter wiring AQ131
Don S
Re: Starter wiring AQ131
I don't recall ever seeing a starter solenoid like that one, but only one of those small terminals is used for starting. The other one should not be used for your engine.
Have you checked for power at the end of the yellow/red wire when you turn the key to the start position? If no power, you may have a problem with the start relay not working.
Have a look at this thread.
http://forums.iboats.com/showthread.php?t=167035
You can download a manual with a wiring diagram in it up in the Adults only sticky,
