hookemdano
- Jul 21, 2009
- 16
I am helping a buddy try to solve a problem, so be kind...
1996 Volvo 5.7GLIPLKDCE throttle body injection
4110143477
3868732
Runs @1200-1400 RPM for 1.5 to 2 minutes then dies. Turn key on,
and hear the fuel pump run for 2 seconds then stops, repeat
this for 5 or 6 times, it will start and run 1.5 to 2 minutes, then dies, you can repeat senerio
for ever. It just will not idle nor stay running.
I have replaced the following:
High pressure fuel pump
2 injectors
float valve & seat in the "fuel resevoir"
cleaned the fuel system
replace fuel/water filter
any thoughts for him to check? Thanks
4110143477
3868732
2 injectors
