88wellcraft
- May 9, 2007
- 208
Hey everybody. Just took out a new to me 2000 Four Winns Horizon 200. It seemed to run fine on our test drive before i bought it but now am running into some issues. First of all the required info.
Engine:
5.0 GI PWTR
4110197437
3868945
Outdrive:
Type: SX-M
Product #: 3868891
Ser #: 4112084001
Ratio: 1.60
I dropped the boat in the water and it started up just fine. I let it warm up to operating temp and took it out for a cruise. At slow Idle speeds i noticed it seemed to be running a little rough...almost like it was about to die. It seemed to run fine at planing speeds. I also noticed the voltmeter on the dash looked a little low to me but i wasn't sure where normal was supposed to be on this boat.
after about 30 minutes cruising around i idled around a little....still running rough....the i throttled up and it kind of hesitated and it was kind of like a little backfire sound.
ran it about 3000 rpm for about 20 minutes and almost back to the boat launch and it totally cut out but the engine didn't die. I had been keeping an eye on the voltmeter and it seemed to be slowly going down (no numbers on the meter except at the ends.) At times the meter would jump halfway up the gauge and the boat seemed to run fine for a few seconds. the meter was all the way to the left when it died off the planing speed.
my question.....seems like a charging problem to me...i plan on full tune-up and checking alternator for correct voltage output. Just wondering if there is anything that typically goes wrong on these?(I know....it's a boat)
i spent some time searching for similar problems and got some good ideas (ignition module?) but wanted to double check before i go digging into it.
Awesome forum
thanks for the help
Guy
Engine:
5.0 GI PWTR
4110197437
3868945
Outdrive:
Type: SX-M
Product #: 3868891
Ser #: 4112084001
Ratio: 1.60
Awesome forum
thanks for the help
Guy
