skiffguy18
- Apr 15, 2011
- 10
First off I must say I have read many many posts here over the last 6 months and have never had to post due to the help provided by previous questions. Thanks to all for that. I purchased my boat about 6 months ago and have tackled every issue that came my way but this one is stumping me. I recently rebuilt the raw water pump and the heat exchanger and the boat ran great all day Saturday. I dropped the boat in the water monday started it up and backed off the trailer and it died and wouldn't restart . I have narrowed it down the the fuel system. There is no fuel getting to the carb. I changed all the fuel filters and verified the screen at the carb inlet was not plugged. I removed the pump and bench tested it with 12V and it ran (did not pump fluid just verified it makes noise). Hooked my meter to the fuel pump harness and turned over the motor and got 10V to the harness. Poored fuel into the carb started it up and got 12.5V to the harness with the motor running before it died. That is were I'm at currently and could really use some advice as to were to go next. I was thinking about connecting 12V to the pump and see if it is actually pumping fuel? The way I understand it is the fuel pump runs off normal battery voltage when you are starting it and then switches over to alternator power when the key is released ? Could the diode in between the alternator and the fuel pump relay be bad? If so were is that damn thing? The green wire comes off the alternator, into the harness, and then comes out at the relay. If that diode is bad could that make the pump not work? Wouldn't the 10V on startup be enough to at least make the motor start? Any help would be greatly apreciated. Fishing is just starting to pick up and my boat won't start :facepalm:
