Volvo DP-G trim cylinder leak
mr. sandman
2003 DP-G VP out-drive coupled to KAD300
I noticed a slight leak out of one of the cylinders and thought there would be a simple repair kit. After looking up the price for replacement I dug further and it seems that some have used part number 3854247 which is a seal kit for similar trim cylinders.
1) do you know of a sealing kit for the DP-G drive trim cylinder?
2) do you think the 3854247 kit would work on this trim cylinder?
Re: Volvo DP-G trim cylinder leak
Donno, but most rams, if Different, need Different seals...
