diejarjardie
- Feb 15, 2011
- 12
Howdy Y'all,
I've enjoyed reading the forums here, they are very informative. I never thought I would have to post for help, at least not for this type of problem, but here it goes:
I have a 2000 Larson 186 Lxi that I have had for 4 years. I have done all the pm myself including winterizing. It was really nice this weekend here in Austin, so I thought I would pull the boat out, de-winterize and go for ride on the lake.
I put the battery back in, checked all the fluids, hooked it up to the hose and it cranked right up. I walked around to the outdrive to make sure it was pulling water in, and that water was coming out and noticed a little stream of milky, oily water coming out of the bilge. I then looked at the engine and milky oil was oozing out from under the carb cover and had covered the entire top of the engine. (Please see attached picture). It had been running about 5 minutes.
After reading other posts, I have the following questions that I need help with.
1. How can I isolate where the raw water is leaking into the oil?
2. Will a cracked intake manifold allow water into the engine oil?
3. Will I be able to eyeball the intake manifold once it is off the engine and see cracks, or do you have to test it somehow?
4. Could a leaking intake manifold gasket cause this problem?
Thanks for your help and let me know if you need more information.
