Re: volvo 280 intermediate shaft repair
vinney, not looking for an argument, just interested in your last post. I run a workshop (22yrs automotive) and would like to know how unforseen problems equals lack of knowledge. <br /><br />Threads are sometimes damaged no matter what the bolt material is or how much care is taken - do you every need to fit helicoils? What if the rear main is leaking? Do you replace it without charge or is cost already factored into your flat rate?<br /><br />I run a 280vp/302w and recently had the same problem, my gimbal bearing (bell housing bearing/ intermediate bearing) pratically siezed and badly damaged the housing (3 mths after purchase), I sourced a good secondhand bell housing. What would you have done? Would you charge more than your original quote? Would you have know about the damaged housing before inspecting it (maybe its a common problem - I dont know)? While the motor was out I replaced a worn vibration damper (coupler?)rusty sump and engine mounts.<br /><br />Maybe I've read your post wrong, if so I apologise. As I said, i'm truly interested how a workshop charges for unforseen problems - if you've never had one, you are to be congratulated, I'd like to know your secret.<br /><br />Aldo
