hello i had a number of problems last summer my tach was bouncing around and the motor would bog down and stall a marina installed a aftermarket coil and it didnt fix the proble so i put in the proper coil and im just wanting spring to arrive so i can test it out do you guys think it might be fixed would a bad coil do that to the tach and stall out the motor as if there was no gas????
