Re: 1998 volvo 5.0 changed to 5.7, enough fuel to throttle body?
this system doesnt use MAF, it simply uses a MAP.
all the MAP does on that system is give the ECU information on engine load and baro pressure at key on.
dunno about this guys issue, the only upgrades from the 5.0 to the 5.7 I ever did we used the 5.7 injector part numbers,TB kit and the 5.7 ECU.
typically marine ECM's dont monitor the baro pressure they lock it in at the start of the key on cycle and use that as the standard for the rest of that cycle.
no need to constantly measure baro as most boats dont change altitude much in a single key on cycle.
its all about keeping the A/F mix at about 14.7/1.its also why motors now have pre and post catalyst O2 sensors.
while marine ECM's are dinosaurs compared to the automotive world they are gaining fast.
its ALL about moving air.
thats all an articulated rod internal combustion engine is, its an air pump.
so if the injectors and ECM are set up to provide the 14.7/1 air/f mix for moving a theoretical 5.0L of air and suddenly without anyother changes you move the theoretical 5.7L of air you just altered the air to fuel ratio towards the lean side.
remember,MEFI1,2 and 3 cannot and did not monitor MAF just intake pressure to sense engine load.
so the injectors size,the fuel pressure and the airflow through a known throttle into a known cubic liter displacement are all mapped into an ECU.
the design engineers were pretty good. but yes the basic injector on time is a design function of piston travel time,fuel rail pressure and injector size.
its also why the Z3.3L yamaha engines use 1100 PSI on the rail.
we simply dont have enough time at 50 PSI to move that amount of fuel,ignite it and get it out in about 1.5" of piston travel.
at 5000+ RPM.
look up the parts for both the WT model 5.0 and 5.7.
if the injector part numbers are the same then they are the same injector.
think of the TBI as a precision fuel sprayer.
also pay attenion to the spray pattern.
dirty injector filters and nozzles can make it dribble instead of a nice cone spray.
that motor doesnt like dribbles.
