honeys money
- Nov 18, 2008
- 77
I have a 1998 Larson with a 135HP and SX-M out drive, my problem is, it is in forward, when you move the lever to reverse or neutral, it stays in forward. I looked at the bottom of the shifter and the shift cable does not seem to move, to make sure I jumped the neutral switch and sure enough it stays in forward, ran it around and throttle works fine. My question is how do you get the shift lever off, and take the rest apart.
