I have a 2000 Larson deck boat with a 1999 Volvo Penta 5.7PEFS (gray engine) in it and a VP Cobra SX drive. The boat is new to me this year and has been running great for the 20 hours or so I have put on it.
I decided to change out the impeller because I had no idea when (if ever) the impeller had been changed. Glad I did it because 7 of the 12 vanes on the old impeller had a chunk missing. Some of the vanes had large pieces missing, and some of the missing pieces were small. That leads me to my first question:
1. Do I need to find the missing impeller pieces? Keep in mind that the engine has never overheated (since I've owned it) and runs perfectly. If I do need to find them, how do I go about doing that?
While I was changing the impeller I noticed that an electrical wire on the thermostat housing was unplugged. I assume that this is a temperature sensor. However, my temperature gauge in the dash works great and tracks water temperature as expected (starts out cold, then stays steady at 173-175 on the gauge.
2. What is the sensor on the side of the thermostat housing?
Thanks!
Thanks!
