magicbandit
- Nov 18, 2002
- 27
Hey folks,<br />Heres the scoop. I just bought a 1990 Formula with the volvo 454. Discovered water in the oil.<br />The engine run absoulutely beautiful.Idles great,sounds great, plenty of power.<br />The previous owner put a new medium rise aluminum intake manifold on it. The rest of the engine looks original. also the boat has always been a freshwater boat.<br />I have read some of the similar problems on the forum and have discover a variety of scenarios.<br />1. cracked block<br />2. head gasket<br />3. intake manifold gasket<br />4. oil cooler<br />5. exhaust manifolds/risors and gaskets<br /><br />If 1-3 were possibilities would the engine run as great as it does?? I plan to pressure test the oil cooler tomorrow which should be easy to do.<br />If that test ok i will move to the manifold and risor system. How do you pressure test the risors and manifolds??? I'm kind of bumbed out seeing this is my first boat. Ive pput 1 hour on it and its already broke.<br />Any help would be greatly appreciated.<br />Thanks folks<br />Mike
