HI,Just got a 88 berretta with volvo 131a mtr. Question is what wires supposed to run to pos. side of ign,. coil.Prev. owner took out electronic conv. kit said he had red lead from kit hooked to purple wire lying about wher dinser wouldve went on dist. And black lead from elct.kit ran to coil pos. that just dosent sound rt. W ant to put points back in but, wiring diagram shows lead from ign. switch to coil pos.as well as lead from dist to condinser. Problem is i only have 1 wire its purple ands long enough to lay by were condiser would go.do i need to know if that wires for coil pos. or condinser. C ant find any other wires in that area. looked at wiring on a 1983 125 aq had 2 purple wires 1 to condinser one to pos coil .also this one has a purple and a gray hooked to neg coil term. just dont know where wire to pos. is . thanks in advance . ernie
