This is on my AQ125A and is the hard plastic housing on the top of the heat exchanger. The old one had a crack in it so I picked up the same part no. on ebay. Easy to replace. But the base of the new (used part) does not mate up completely with the metal H/E so water leaks out.
Looks like I have two choices:
try to sand or grind the base of the housing to fit flush or find a permatex or some other sealing compound and seal up the joining surface.
What would you suggest?
What product can I use to seal the surface, which would be the easiest solution , I think.
thanks,
Joe
thanks,
Joe
