Reinell185
- Feb 5, 2010
- 6
Hi Guys.
Thought I would try my hand at a forum post to see if I can get my Penta sorted, before I take it to the machanic.
Engine is Volvo Penta 4.3ltrGL 190hp V6 Carby 1997 stermdrive. It has EST ignition and a 2bbl std carby. Was running well last weekend and it died out on the water. Cut a long story short, here is what I have done so far.
Replaced Coil. Replaced Ignition Control Module. Replaced fuel pump. Checked all ignition components as per the Seloc Manual and check status is good. Checked all fuses and wiring to the engine. Checked power to all breakers & relays to be present as per Seloc diags. Double checked the wiring loom from Ignition coil (4 wires) to the distributor pick up coil, buzzed with multimeter & test light, ok. Checked distributor coil pick up with multimeter as per Seloc, not grounded, not shorting, so tests ok.
Problem is that I have no spark, either from an earthed test plug from one of the 6 cylinders fro dist cap, or direct high tension wire from the coil to ground. Motor cranks ok, and plenty of fuel getting through, also is a new fuel pump, so its not fuel problem, definatly electrical. I changed the Ignition control module as I thought the trigger signal to the ignition coil from this may have been suspect, but still no spark. Plugs and leads are good and have also checked microswitch & wiring in the selector controls to be good. Wiring has been checked using circuit diagrams, test light & multimeter, unless there is a hidden broken fuse somewhere, I am stumped!!
I have read a lot of posts, and tried a lot of tips taken from them, but not able to rectify the problem.
Cheers Andy.
Cheers Andy.
