The seawater cooled collar appears totally blocked by mineral deposits (left unused for a year). Suggestions for clearing this out have included a weak acid but I wonder whether this cooling function is ONLY for reversing or is it needed for the gear box/engine when engaging forward? The basis of the Q is whether I can simply bypass the blocked collar and take the seawater from the intake hull fitting directly to the water pump.
